I have a simple code to read data from FPGA using GPIF II and send via USB. I need only one RD signal to read data from FPGA bus. RD LOW level drive 16 bits data bus. RD HIGH close FPGA data bus and incremet internal FPGA adress counter. Each time I want to read data with different length.
DMA CONFIG code
/*------DMA P-Port config (AUTO mode)---------------------------------------------------------------------------------------------*/
dmaCfg.notification = 0;
dmaCfg.cb = NULL;
dmaCfg.prodSckId = CY_FX_PRODUCER_USB_SOCKET_4;
dmaCfg.consSckId = CY_FX_CONSUMER_PPORT_SOCKET;
dmaCfg.count = 1;
apiRetStatus = CyU3PDmaChannelCreate (&glChHandleSRamUtoP_48, CY_U3P_DMA_TYPE_AUTO, &dmaCfg);
if (apiRetStatus != CY_U3P_SUCCESS)
CyU3PDebugPrint (CY_FX_DEBUG_PRIORITY, "CyU3PDmaChannelCreate failed, Error code = %d\n", apiRetStatus);
CyFxAppErrorHandler(apiRetStatus);
dmaCfg.cb = NULL;
dmaCfg.prodSckId = CY_FX_PRODUCER_PPORT_SOCKET;
dmaCfg.consSckId = CY_FX_CONSUMER_USB_SOCKET_8;
dmaCfg.count = 1;
apiRetStatus = CyU3PDmaChannelCreate (&glChHandleSRamPtoU_48, CY_U3P_DMA_TYPE_AUTO, &dmaCfg);
CyU3PDebugPrint (CY_FX_DEBUG_PRIORITY, "CyU3PDmaChannelconfig Failed, Error code = %d\n", apiRetStatus);
Working cycle
for (;;)
uint32_t counter = 8;
GpifReadEnd = CyFalse;
CyU3PGpifInitAddrCounter (0, counter, CyFalse, CyTrue, 1); // loading addr count
apiRetStatus = CyU3PGpifSMSwitch (256, RD_START, 256, 0, 0); // start condition after switch GPIF II
if(apiRetStatus != CY_U3P_SUCCESS){
CyU3PDebugPrint (CY_FX_DEBUG_PRIORITY, "CyU3PGpifSMSwitch failed, Error code = %d\r\n", apiRetStatus); }
while(!GpifReadEnd){} // FLAG that assert in interrupt function
Why RD level is LOW after last read cycle on oscilloscope but in GPIF Desinger show RD = HIGH?
When I tried to paste empty state between RD_START state and RD_LOW state, RD signal asserted HIGH, but I have one more read strobe. Why?????????
