USB Superspeed Peripherals
brjo_4790056
New Contributor
I have followed several threads regarding this topic.  I see most of them end without clarification that "solutions "worked as there were follow up questions that were never answered.
I have a 1920x1200 sensor running at 45fps which I know surpasses the parallel pixel clk of 100 Mhz.  I would like to pack the pixels to a 24bit image.  As stated above, I have tried to follow a lot of the threads and tried many of the settings with no success. I'm looking for a little support, with using the EZ USB suite.  Will it correct create the c files if setup they way I want (as above) or do I have to massage the settings once it creates them (i.e. frame size, image size, etc.?)
Rashi_Vatsa
Please refer to this KBA https://community.cypress.com/t5/Knowledge-Base-Articles/Streaming-RAW10-Format-Input-Data-to-16-24-...
Also, please share the CX3 Configuration tool's "CX3 Receiver Configuration" tab settings for us to check.
Rashi
Rashi_Vatsa
Rashi
