05:36 PM
Jul 07, 2015
05:36 PM
I am using CX3 interfaced with Omnivision sensor Ov4682. I have omnivision sensor register settings defined in a .c file. I use UVC/Directshow to output the image. If I have to change a single register, I have to build the solution and flash the image on firmware. Can I use Directshow or any other means to change the sensor values dynamically? What changes do I have to make in firmware to support this?
