Feb 14, 2019
12:54 AM
Feb 14, 2019
12:54 AM
Hi
I used the official example cyfxbulklpauto_cpp, the code makes the following changes:
EP config in super speed mode:
1. epType is set to CY_U3P_USB_EP_BULK
2. burstLen is set to 2
3. pcktSize is set to 1024
DMA config:
1. size is set to 1024
2. count is set to 8
When the data source rate is high (the speed more than 100Mbp/s), I run the C++ streamer, it works normal.
However, when data source rate is high (the speed less than 20Mbp/s), I can't receive any data from CY3014
I saw on BBS that other people had the same problem, but there was no answer, How can I receive low speed data from CY3014?
