Sep 29, 2021
06:56 AM
Sep 29, 2021
06:56 AM
We were testing of the Designing A GPIF™ II Master Interface concept using CYUSB3KIT-003 kit and try to send data from Slave to Master and Master to Slave in line with the document AN87216. We observed that the transmission is happening in same PC having two USB 3.0 port.
But when we are connecting between two PC (One PC ->Host ,Second PC->Slave), the Slave USB device is not able to transfer data to Master USB and only master to slave data transfer is working.
How to transfer data from Slave to Host using CYUSB3KIT-003 kit between two PC?
Labels
02:00 AM
Sep 30, 2021
02:00 AM
Can you please confirm if the default GPIF II state machine is used or not?
Also, please share the UART Debug prints of the both FX3 while the application is running.
