03:32 PM
Apr 24, 2012
03:32 PM
Hi
I have a problem wih the CYUSB3014-BZX. it does not enumerate (windows does not detect a usb device) when the rising edge of the +5V supply is in bad shape. I have to do a hard reset. I try to hold the reset pin for 200ms while the +5V is unstable without succes (respecting the reset sequence in the datasheet). We sometime have this problem on the CYUSB3014-BZX evaluation board. What is the correct reset sequence?
