Hi Everybody.
SDK is updated.(SDK v1.3.3)
AN65974 Sample is not boot.
(SDK v1.3.1 is OK)
Let's me know, What is worng for me.
Best Regards.
Jade, Lee
The firmware does work. However, with the 1.3.3 release of the SDK, it won't compile by default. This is because we're now using an updated version of GCC.
You can go to the project's properties, navigate to C/C++ Build > Build Variables and then add "ARMGCC_VERSION" as a build variable with "4.8.1" as the Value and "String" as the Type.
I found the seem problem.
In Eclipse show:
arm-none-eabi-gcc: C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\/lib/gcc/arm-none-eabi/4.8.1/libgcc.a: No such file or directory
cs-make: *** [SlaveFifoSync.elf] Error 1
I found in my pc, there is only one
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\lib\gcc\arm-none-eabi\4.5.2 folder.
How to solve this problem?
I solved this program.
I think eclipse project have compiler option & information.
App note formware is created 1.3.1 eclipse project, this is my guess.
So I create new project width 1.3.3 eclipse.
It's working good.
Thanks to people interested.
Have a nice day.
I have solved the problem too.
The download SDK 1.3.3 link is wrong, if you don't download the SDK by the download tool "Akamai Download Manager (DLM) ",
just "download the file without using the download manager", the download file is SDK 1.3.1.
I am having the same problem but I cannot find SDK 1.3.1.
The "You can go to the project's properties, navigate to C/C++ Build > Build Variables and then add "ARMGCC_VERSION" as a build variable with "4.8.1" as the Value and "String" as the Type." suggestion didn't do anything regarding this problem.
What do I do?
try reinstall the SDK in another directory which doesn't include "Program Files (x86)" .
