I am using Multicasting example firmware which came with SDK.I want to transfer the same data from P-Port to U-Port and S0-Port.
dmaCfg.prodSckId[0] = CY_FX_EP_PRODUCER_SOCKET;
dmaCfg.consSckId[0] = CY_FX_EP_CONSUMER_1_SOCKET;
dmaCfg.consSckId[1] = CY_FX_EP_CONSUMER_2_SOCKET;
I declared above prod and cons sockets as
#define CY_FX_EP_PRODUCER_SOCKET CY_U3P_PIB_SOCKET_0/* Socket 1 is EP1 OUT */
#define CY_FX_EP_CONSUMER_1_SOCKET CY_U3P_UIB_SOCKET_CONS_1 /* Socket 1 is EP1 IN */
#define CY_FX_EP_CONSUMER_2_SOCKET CY_U3P_SIB_SOCKET_0/* Socket 2 is EP2 IN */
After the above changes,the device is not enumerating in Control center.Why?
Srujana.
Hello Srujana,
Please confirm that did you start and initialize the sib block before creating the DMA channel
Rashi
Rashi
