Hello I'm using FX3, for debug purpose I'm using Tera Term, to see data sent from FX3, for basic start , I tried to print "Hello world" but all I got is messy data. what's the problem?
and serial port settings
Thank you.
USB Superspeed Peripherals
1. Please check if the DebugPreamble is set to False.
2. Please try to use a different usb serial device and let us know if the issue persists.
AliAsgar
There is a possibility that this may be a problem with the cable used to connect the UART port to the PC.
1. Could you try using different cables and different ports on the PC and see if the issue still persists?
2. What is the application? Which FX3 firmware project is used? What are the modifications done to the default firmware?
3. Is superspeed explorer kit being used? If yes, could you share your firmware with us, so that we can try to reproduce the issue at our end.
AliAsgar
AliAsgar,
I'm using denebola kit, I'm using OV5640 firmware, just tried to print "Hello World" at the end of Debuginit function.
I already used 3 new cables but same problem persists.
Are the debugPrints coming in using a CDC or through a UART port? If through a UART port, is a USB Serial kit connected to the denebola kit for this purpose?
Are the other debugPrints working fine, which are in the default SDK.
AliAsgar
I'm using UART port ,and I also tried to run debugPrints from default SDK but not working,
I'm using cyfxuartlpregmode example from SDK to test but its not perfectly working.
Result of using cyfxuartlpregmode :-
as you can see first I long pressed d then e then g, sometimes characters are printing but sometimes unexpected data is printing.
AliAsgar
