I am transferring data from P-Port of FX3 to S0-Port of FX3 and then to SD Card.For that i am using the below attached firmware.Initially,the device is enumerating as Bootloader device but after programming with below firmware endpoints are not detecting.IO Matrix API is failing what is wrong in IO Configuration Matrix?Can anyone please help me.
when i am adding this to check API success,the device is reseting after programming.
status = CyU3PDeviceConfigureIOMatrix (&io_cfg);
if (status != CY_U3P_SUCCESS)
CyU3PDeviceReset(CyFalse);
goto handle_fatal_error;
When i am checking this API after debugging
Srujana.
Is the below Configuration correct in terms of GPIO Pins?
io_cfg.s0Mode = CY_U3P_SPORT_4BIT;
io_cfg.s1Mode = CY_U3P_SPORT_INACTIVE;
io_cfg.useUart = CyTrue;
io_cfg.useI2C = CyFalse;
io_cfg.useI2S = CyFalse;
io_cfg.useSpi = CyFalse;
#if (CY_FX_SLFIFO_GPIF_16_32BIT_CONF_SELECT == 0)
io_cfg.isDQ32Bit = CyFalse;
io_cfg.lppMode = CY_U3P_IO_MATRIX_LPP_DEFAULT;
#else
io_cfg.isDQ32Bit = CyTrue;
#endif
/* No GPIOs are enabled. */
io_cfg.gpioSimpleEn[0] = 0;
io_cfg.gpioSimpleEn[1] = 0x00000000; //for spi
io_cfg.gpioComplexEn[0] = 0;
io_cfg.gpioComplexEn[1] = 0;
Srujana.
Srujana,
It looks like this thread is duplicate of EndPoints are not Enumerating
Please do the following modifications:
As per the above IOMatrix configuration, you are not supposed to use GPIO 53 to 56 pins as GPIOs.
These pins are mapped to UART block when we set LPP MODE to CY_U3P_IO_MATRIX_LPP_UART_ONLY.
I can see that you are using GPIO 53 to 56 for SPI (as per comment). Hence, the IOMatrix is failing.
Since you are not using Storage port #1, you can enabled SPI and UART (I2S too if needed) and set the LPP MODE to CY_U3P_IO_MATRIX_LPP_DEFAULT.
With the following settings, the UART and SPI block are mapped to UART - Pins 49:46 and SPI - Pins 56:53.
io_cfg.s0Mode = CY_U3P_SPORT_8BIT;
/* If the UART is used for logging, we can only configure the S1 port as 4 bits wide. */
io_cfg.s1Mode = CY_U3P_SPORT_INACTIVE; //CY_U3P_SPORT_4BIT;
io_cfg.lppMode = CY_U3P_IO_MATRIX_LPP_DEFAULT;//CY_U3P_IO_MATRIX_LPP_UART_ONLY;
io_cfg.useI2C = CyTrue;
io_cfg.useSpi = CyTrue;
I made the changes as u said but i am still getting the same issue.
#else
#endif
Srujana.
Srujana,
Is the device coming up as Bootloader after loading the slavefifosync firmware?
Sridhar
Before the device is coming up as Bootloader after loading the slavefifosync firmware.
Now after making the above changes,it is not coming as Bootloader after loading the slavefifosync firmware.
After Programming:
Srujana.
Hello Sruna,
It means the IOMatrix API returning sucess and there are some other errors coming up later in your code.
Earlier you have configured GPIO for SPI and in latest code you have configured to use SPI hardware block.
Please check whether you are still configuring the GPIO 53 to 56 in your code.
If you have feasibility for UART prints, you can findout where it is failing. Otherwise, you can use JTAG debugging and findout the same.
Sridhar
#else
#endif
Srujana.
Srujana,
It is correct.
Note that the UART block is mapped to Pins 49:46.
Since you are using FX3S, you do not need CY_FX_SLFIFO_GPIF_16_32BIT_CONF_SELECT macro in your code. You can delete this macro and use only GPIF 16 code.
Sridhar
Apologize me for asking minor doubts.
As i posted screenshot in above replies, i am getting IO Matrix Status as
what do you mean by GPIF 16 code?
Srujana
Hello Srujana,
Please do one more STEP IN and get the status variable value. You will come to know whether it is entering the If condition.
GPIF 16 code means,
In the slave fifo, there is a macro CY_FX_SLFIFO_GPIF_16_32BIT_CONF_SELECT. This is needed if you are using FX3.
In case of FX3S, you have only 16-bit GPIF. Hence, you don't need this macro in your code.
Since there is no requirement of the macro, you can remove it from the code to avoid the confusion.
For example:
Thank you for giving clear explanation.
Yes,I did and it is entering the If condition
Please tell me which part of firmware may be the issue for not enumerating endpoints?
Srujana
Srujana,
Please do JTAG debugging further to know what else is failing.
You may refer this thread
Sridhar
Hi Srujana,
I can see there are two threads in your application.
It looks like it entering into CyFxAppErrorHandler during run time.
You can quickly confirm this by placing CyU3PDeviceReset(CyFalse) in CyFxAppErrorHandler funtion.
Once it is confirmed, you need to find out where the application entering into CyFxAppErrorHandler.
You can also use JTAG debugging to find where it is entering to CyFxAppErrorHandler
Sridhar
