I use api "CyU3PDeviceConfigureIOMatrix" to enable some GPIOs, while enable it, Is it high or low for these GPIO's? how to set to high while is enabling?
Hello Peter,
You can configure the GPIO:
CyU3PGpioSimpleConfig_t gpioConfig;
/* Configure GPIO 21 as output */
gpioConfig.outValue = CyFalse; //This will set the initial value of the GPIO to Low. You can set initial value of GPIO using this field
gpioConfig.driveLowEn = CyFalse;
gpioConfig.driveHighEn = CyFalse;
gpioConfig.inputEn = CyTrue;
gpioConfig.intrMode = CY_U3P_GPIO_NO_INTR;
apiRetStatus = CyU3PGpioSetSimpleConfig(21, &gpioConfig);
You can also refer to the GPIOAPP example of the SDK Path : \Cypress\EZ-USB FX3 SDK\1.3\firmware\serialif_examples\cyfxgpioapp
Rashi
Rashi
