04:35 AM
Sep 28, 2018
04:35 AM
Hi!
My custom instruction is sent to FX3 via EP0,that is Supplier instructions via EP0,
First, the instruction is sent to FX3 through EP0, and FX3 receives the instruction, and then the required data is returned through EP0,
For this demand,
how should the host application be written, I did not find the corresponding sample,
Could you give me some advice?
Thank you!
09:58 PM
Sep 30, 2018
09:58 PM
You can refer to the Cypress USB Control Center application source code that comes with the FX3 SDK. In this GUI application, look for the code corresponding to "Transfer Data" button click which implements the data transfer over different USB endpoints including the control endpoint EP0.
Srinath S
