USB Superspeed Peripherals
I need to verify the operation of my code running USB2.  Whats the easiest way to force my client to boot in USB2 HS mode, even when connected to a USB3 host?
Ken
LiMa_282146
New Contributor II
Use a USB 2 cable - it will work with the USB 3 host but only bring the USB 2 signals to your device.
Sodafarl
