USB Superspeed Peripherals
I notice that 4-wire designs are absent from AN70707 PCB Guidelines. Can you please verify the feasibility of my proposed 4-wire microSD connections? In particular, that I am free to ignore signal WP, which does not exist on my microSD connector. VIO2 working voltage is 3.3V. What considerations are required to lower this voltage to 1.8V?pastedImage_2.png
TIA!
This schematics looks fine. There isn't any special consideration for 1.8V. It is enough if you connect the VIO2 to 1.8V.
Make sure the firmware has io_cfg.s0Mode = CY_U3P_SPORT_4BIT in CyU3PDeviceIOConfigure
and lowVoltage = CyTrue in CyU3PSibSetIntfParams API
-Madhu
