soqi_4187516
250 sign-ins 100 sign-ins 50 sign-ins
     I use FX3 with the sensor IMX316, the resolution is 480*182 @ 30fps, raw12. The mipi clock is 200MHz
1. I can't get the correct datas. I add log, shows below. The CyU3PDmaMultiChannelGetBuffer get data error. It is confirm that the sensor can output datas correctly (I measure the MIPI signal, it is correct).
CyCx3AppStart 863
AplnStrt:CyCx3AppStart
AplnStrt:SMState = 0x2
CyU3PDmaMultiChannelGetBuffer failed status = 0x0
2. But i catch the package, it seems that PC can get some disorderly datas.
3. The configuration is as below:
Is there someone who can  give some suggestions? How to debug it?
Hemanth
First like given First question asked 750 replies posted
I see that the Data format in 'CX3 Mipi Interface Configuration' section is chosen as RAW12. Doing so will cause the MIPI block to drive 12 GPIF data lines and remaining 4 would be sampled as zeros (I assume you would have configured the GPIF to be 16 bit wide in your firmware)
So, to change it you can choose output format as 16-bit and configure the GPIF bus width as 16. Let the 'Data format' in the in the CSI-2 MIPI Inputs section be RAW12 since your image sensor data might be RAW12.
Also look for any errors on the UART and the CX3 configuration tool (Please use the tool which is there in SDK 1.3.4).
Hemanth
Hemanth
soqi_4187516
The CyU3PDmaMultiChannelGetBuffer can get data now. But the data still abnormal.
Hemanth
Hemanth
Hemanth
Hi, Thanks for you support. I have solved this problem, thanks!
