USB Superspeed Peripherals
LiMa_282146
New Contributor II
Could someone confirm the pcb pad sizes for the FX3 BGA package. Cypress application note AN70707 p2 gives the recommended pad size as 0.241mm but the development board has a pad size of about 0.5mm. Has anyone built a pcb using the recommended pad sizes for the FX3.
Sodafarl
