FX3 Slave Fifo Interface - FIFOADDR pins
Hello
Thank you for your help
If I am writing data into the Slave FIFO and I hit the 512 endpoint buffer size is there an auto increment mode whereby the FIFOADDR0 and 1 are internally incremented?  If I keep writing into the same endpoint buffer will my data get overwritten?
See in our FX2 design we are able to externally just keep FIFOADDR 0 and 1 tied to a 0 but we keep writing data into the FIFO and it internally increments the buffer.  Is this possible in the FX3?
Gary
