11:24 PM
Feb 15, 2018
11:24 PM
How ez-usb-fx2lp automatically loads c2 load eeprom boot(24LC128-16KB-2 bytes address)?
which eeprom will select if i connect two eeprom with same size to fx2lp on I2C bus?
10:31 PM
Feb 18, 2018
10:31 PM
The EEPROM selection is based on its Slave address. Both the EEPROMs should not have the same I2C slave address. Please refer to the FX2LP Technical Reference Manual or the datasheet to determine the correct slave address to boot from I2C EEPROM.
