USB Superspeed Peripherals
MiVi_1497601
New Contributor
Is there a way to set the (Serial Number) SN in the device properties it is currently set to nothing.
shkuc_292731
New Contributor II
Hello Miguel ,
yes, you can change the Serial number string from the USB descriptor on the firmware.
From an application perspective, If you need to differentiate the two devices on your application means you can use the device path on windows.
Thanks & Regards,
Shanthakumar
