USB Superspeed Peripherals
Subhash24
New Contributor
           I'm working with Denebola kit, so my question is does the data I'm receiving from OV5640 contains header, does uncompressed YUV2 contain header?
Thank you
JayakrishnaT_76
Please let us know if you are talking about the UVC header which is added by CX3? If not, then please elaborate your question so that we can understand it better.
As you might be knowing, CX3 (MIPI to USB bridge in Denebola kit) accepts the video data from the image sensor (OV5640 in Denebola kit) over the MIPI interface, adds UVC header and sends it to the host. The UVC header is added inside the CX3 firmware and not by the image sensor.
Jayakrishna
Subhash24
New Contributor
           ov5640 contains ISP right, does it add header to image?
JayakrishnaT_76
Please check with the sensor vendor to understand if the sensor adds any header to the image or not.
Jayakrishna
