Hi Sir
I want to Display the RAW12 data in YUV format,I read the FAQ via the website: https://community.cypress.com/docs/DOC-9371 .And about the topic 10, it told me that I could get an example firmware. So, Which access could I get it ? If not ,which parts need to be changed based on the example firmware “Cx3UvcOV5640”?
Best Regards
ZhaiJiankun
- raw12 uvc
Hello ZhaiJiankun,
If you want to send the RAW12 video data as YUV to the USB host , then you need to modify the descriptor as follows:
1)Implement the UVC descriptor frame work
2)Set the video format as YUV in the format descriptor.
Please note that we are not doing any video conversion in this case. You have to implement the video format conversion in the host application.
