USB Superspeed Peripherals
cam
New Contributor II
I am wanting to probe the VSYNC_test on the Denebola board but it is not clear where it is located.
Can you please share the location?
JayakrishnaT_76
Please find the snapshot below that shows the location of the test points:
You can also refer to the following thread which has a snapshot of the test points marked on the board:
https://community.cypress.com/t5/USB-Superspeed-Peripherals/e-con-CX3RDK-test-pin/td-p/208205
Jayakrishna
JayakrishnaT_76
Jayakrishna
