I just installed FX3SDKSetup_1.3.4.exe & SuperSpeedExplorerKitSetup_RevSS.exe.
And UVC_AN75779 firmware that was supported from cypress site.
but I can't build this....
there are messages "Program "arm-elf-g++" not found in PATH"
and I tried my source.
I got this message.
Program "make" not found in PATH
could you help me to build this....
Please make sure that all the required paths are present in the Environmental Variable. You can find this in Advanced system settings in your PC -> Environmental Variables -> path.
Once this is done, please follow the steps mentioned under Section "3.1 Programming the FX3 device " in the Getting Started with FX3 document present in the FX3 SDK.
Let me know if you are able to import and build the USBBulkLoopAuto project.
Yatheesh
