USB Superspeed Peripherals
gyle_4662476
New Contributor
I just installed FX3SDKSetup_1.3.4.exe & SuperSpeedExplorerKitSetup_RevSS.exe.
And UVC_AN75779 firmware that was supported from cypress site.
but I can't build this....
there are messages "Program "arm-elf-g++" not found in PATH"
and I tried my source.
I got this message.
Program "make" not found in PATH
could you help me to build this....
YatheeshD_36
Please make sure that all the required paths are present in the Environmental Variable. You can find this in Advanced system settings in your PC -> Environmental Variables -> path.
Once this is done, please follow the steps mentioned under Section "3.1 Programming the FX3 device " in the Getting Started with FX3 document present in the FX3 SDK.
Let me know if you are able to import and build the USBBulkLoopAuto project.
Yatheesh
YatheeshD_36
Try uninstalling the setup and reinstalling it with "complete" package installation.
Yatheesh
gyle_4662476
New Contributor
already I tried that..
Uninstalling the SDK and all Eclipse-related files, workspace....
YatheeshD_36
Yatheesh
gyle_4662476
New Contributor
Here is my Environmental Variables -> path.
but still the problem is existed.
gyle_4662476
New Contributor
YatheeshD_36
Did you try the exact steps mentioned in Section "3.1 Programming the FX3 device " in the Getting Started with FX3 document present in the FX3 SDK.
Also, please refer to this thread:Re: FX3 Enumeration Issue "Device descriptor request failed"
Yatheesh
gyle_4662476
New Contributor
"3.1 Programming the FX3 device" is not here
YatheeshD_36
As I mentioned previously, please refer to "3.1 Programming the FX3 device " in the Getting Started with FX3 document present in the FX3 SDK.
Please search for the document in the EZ-USB FX3 SDK installed package, path: <installation directory>\EZ-USB FX3 SDK\1.3\doc\firmware
Document name: GettingStartedWithFX3SDK.pdf
Yatheesh
cycy_1740621
Contributor
It could be observed that the locations of these necessary tools( including arm gcc tool, cs-make tool) are not set correctly in your PATH variable.
