I am trying to debug the USBBulkSourceSinkLED project of CYUSB3KIT003 with OpenOCD in SDK1.3.4.
but, I had an error like below.
I set the "Run Configuratins" like below.
The "arm926ejs_fx3.cfg" file is in the folder below.
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\JTAG\OpenOCD\Config
What shall I do?
Yocchi
☆You can do setup as follows on [Run] -> [External Tools] -> [External Tools Configurations].
Location: C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\JTAG\OpenOCD\Windows\openocd.exe
Working Directory: C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\JTAG\OpenOCD
Arguments: -f Config\arm926ejs_fx3.cfg
This setting is a bit diffrent to the description on "CYUSB3KIT-003 SuperSpeed Explorer Kit User Guide, Doc. # 001-93186" because directory hierarchy on SDK1.3.4 environment is a bit different compare to "C:\Program Files (x86)\Cypress\SuperSpeed Explorer Kit\1.0\USBSerialOpenOCD".
☆If you would like to setup on "Run Configurations", how about following settings on Arguments?
To change "Program arguments" and "Working directory", you would be able to see correctly invoked messages on the Console.
Hirotaka Takayama
Hirotaka Takayama
