USB Superspeed Peripherals
LeRi_4466366
New Contributor
I have a callback registered with CyU3PUsbRegisterSetupCallback and I am not using fast enumeration.
Currently I am using the callback to log setup transactions.
Comparing my log with that from a USB analyzer I can see that I get most SETUP transactions with the exception of SetAddress.
Is it possible for the application to be notified when a SetAddress transaction has occurred?
Hemanth
Hi Levi,
Please refer to register address 0xE0033400 given in FX3 TRM section 10.16.1
Hemanth
Hemanth
Hemanth
SET_ADDRESS is handled by the Hardware and hence application is not notified for the same.
Hemanth
Hemanth
LeRi_4466366
New Contributor
Thanks Hemanth,
Is there any way for the application to read the address after the SET_ADDRESS transaction?
Best,
Levi
Hemanth
Hi Levi,
Hemanth
Hemanth
