IMPORTANT: Cypress Developer Community currently doesn’t allow sign-in to prepare for the upcoming transition. To learn more, check out our announcement.
USB Superspeed Peripherals
mn4888
New Contributor
我使用ezsuit里的USBIsochLoopAuto例程和streamer程序测试速度,发现usb3.0下只有不到8MB/S,我的u盘都可以跑到一百多MB,这是为什么?
Hemanth
FX3 throughput analysis is done in AN86947
Above analysis uses cypress vendor driver cyusb3 - which is different when compared to mass storage driver.
Usually the throughput that can be achieved using mass storage driver will be less compared to cyusb3 driver.
Hemanth
Hemanth
Hemanth
