Hello all,
I found in CyUsb3.pdf the instructions to configure the inf file, although I don't have much experience with inf files in general. I've added my devices VIDs and PIDs, and they enumerate properly, so that's a good start.
I'm currently trying to get the script feature to download the firmware into the FX3 when it attaches. I have it in a state where it creates the registry entry that points to the script location, and I've made sure that folder exists (and it is a subdirectory of System32). If I copy the script manually, it runs and downloads the firmware when the FX3 connects, so that's excellent. The trouble is that it doesn't copy the script into that location when I install the driver.
Is it supposed to copy the script, or am I supposed to do it myself? If so, what have I missed?
While I'm on the topic, is there any way to make the INF file create the folder if it doesn't already exist, or am I on my own for that? It seemed from other answers I saw that it might not be possible to create the folder from the INF file.
I'll attach the files so you can see what I've done so far.
USB Superspeed Peripherals
Please refer to section 2 of Cyusb3.sys programmer's reference in the FX3 SDK (Path: C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc\SuiteUSB)
It mentions the the following:
1. Use the CyControl.exe application to create a script file containing the control transfer commands.
2. Save the script file
3. Place that script file in the same directory as mentioned in the driver's .INF file
>> The folder for the script file needs to be created manually
Please let me know if there are more queries on this
Rashi
