CYAPI library suspend and resume function is support fx2lp
dach_3214351
5 sign-ins 5 replies posted 5 questions asked
the suspend, resume function is support fx2lp.
using  suspend funcrion does not into suspend in fx2lp.
SrinathS_16
- FX2LP supports Suspend and Resume operation.
- The Suspend() function in the CyAPI library is no longer supported. Please refer to section 6.21 of the attached CyUSB.PDF document.
- The CYUSB3 driver puts the device into suspend state after around 10 seconds of inactivity on the bus. Before the device enters the suspend state, the TD_Suspend() function block gets executed.
NOTE: The configuration descriptor should indicate that the device is capable of remote-wakeup. Only, when this is enabled, the driver suspends the device.
Code Snippet:
HighSpeedConfigDscr:
      db   DSCR_CONFIG_LEN               ;; Descriptor length
      db   DSCR_CONFIG                  ;; Descriptor type
      db   (HighSpeedConfigDscrEnd-HighSpeedConfigDscr) mod 256 ;; Total Length (LSB)
      db   (HighSpeedConfigDscrEnd-HighSpeedConfigDscr)  /  256 ;; Total Length (MSB)
      db   1      ;; Number of interfaces
      db   1      ;; Configuration number
      db   0      ;; Configuration string
      db   10100000b   ;; Attributes (b7 - buspwr, b6 - selfpwr, b5 - rwu)
      db   50      ;; Power requirement (div 2 ma)
Srinath S
SrinathS_16
Code Snippet:
Srinath S
Thank you for your reply.
I follow your suggestion, the system can into suspend and resume.
Can I adjust more longer time to entry suspend state? maybe oen minute or more.
This value has been set at the driver level and hence cannot be modified.
Srinath S
