Hello.
I am trying to interface a device with MIPI interface to Denebola CX3 board.
I have an issue with the function CyU3PMipicsiGpifLoad that give me a status of 64.
status = CyU3PMipicsiGpifLoad(GPIF_BUS_WIDTH, CX3_UVC_DATA_BUF_SIZE);
I have used the CX3 config tool to set and generate the project files.
I have initialized the PIB before to launch CyU3PMipicsiGpifLoad.
GPIF_BUS_WIDTH is 16, and CX3_UVC_DATA_BUF_SIZE is 8176.
Could you pleas give me indications how to solve this issue?
Best Regards.
Using a debugger in the Denebola CX3 board, after the line status = CyU3PMipicsiGpifLoad(8,4096); I get
dmaCfg -->{size = 8192, count = 4, validSckCount = 2, prodSckId = {CY_U3P_PIB_SOCKET_0, CY_U3P_PIB_SOCKET_1, CY_U3P_LPP_SOCKET_I2S_LEFT, 35712}, consSckId = {CY_U3P_UIB_SOCKET_CONS_3, 83, 24576, 17628}, prodAvailCount = 0, prodHeader = 12, prodFooter = 4, consHeader = 0, dmaMode = CY_U3P_DMA_MODE_BYTE, notification = 24, cb = 0x400033e4 <CyCx3UvcAppDmaCallback>}
The status 64 should indicate CY_U3P_ERROR_CMD_NOT_SUPPORTED, /**< Storage device failed to support required commands. */
Is the Denebola CX3 not recognized and the system behaves as a FX3? I have used the MiPI template cx3config.cycx to realize the basic application
