07:37 PM
Sep 03, 2016
07:37 PM
I am unsure if this is the right place to ask this specific question, but hopefully someone knows the answer!
In Cypress EZ USB Suite's CX3 Configuration project, in the Frame Configuration, we need to set both H and V blanking values. In the example code for OV5640, H blanking is set to 50 for all resolutions and V blanking set to 5. I went through the spec. and ov's source code, and still couldn't figure out how 50 and 5 were calculated!
I am trying to port the example code to support another OV sensor, so without knowing these two values, I couldn't make the project work.
Thanks!
