USB Superspeed Peripherals
I am interested in using the CX3 for a new project.  The requirements are to stream 640x480 video from an OmniVision OV5640 sensor over USB 2.0 at 15 frames per second.  The CX3 appears like it would be a good fit for this application.  However, I see the Denebola dev kit for the CX3 has a 4 week lead time.  I need something within a couple days.
Is there an alternate source of these dev kits?
If not, is there an alternative dev kit that would get me started before custom hardware boards are available?
And if not, is there an alternative to the CX3, with an available dev kit, that would work for this application?
Thanks...
