Hi All,
In AN90369 at 5.5.1 CX3 MIPI Receiver Configuration the function CyU3PMipicsiSetPhyTimeDelay(..) is mentioned.
I can't find the purpose and or the value to be used as first function argument. I understand the second parameter is the delay value. Maybe i missed somthing. Hope someone can explain.
Thanks!
Help
Please refer below:
first argument: please refer to section 1.10.12 of CX3_TRM which is in the below path of FX3 SDK:
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc
second argument: Time interval during which the HS receiver shall ignore any data lane HS transitions, starting from the beginning of THS-prepare. The CX3 configuration tool calculates the PHY delay. But this is not set in the firmware. For that we have to use CyU3PMipicsiSetPhyTimeDelay()
Please refer below:
Thanks Hemanth!
