Are SPI pins tristated at start in AN84868 configuring FPGA by FX3?
MaXi_1246331
Are SPI pins tristated until the start of configuring FPGA in AN84868? If no configration data are sent to FX3, will the spi pins stay tristated?
abhinavg_21
I can't comment exactly about the state of MOSI and MISO pins. I mostly found that MOSI is in Logic 0 state but MISO is tri-stated.
You can check it but putting "while(1)" loop after the "CyU3PSpiInit()".
Thanks & Regards
Abhinav
abhinavg_21
Thanks & Regards
Abhinav
