Application with FPGA and FX3
MaG
Dear Sir or Madame,
we are currently developing an application in which we are using a panasonic active optical converter (AOC). The AOC however is not able to transmit all the signals in usb3 training signal procedure (LTSSM), because it is only capable of transmitting higher frequency signals.
In order to solve this issue panasonic suggested using the cypress fx3 and a fpga and informed us, that this solution is known to be possible.
The configuration should look like this:
Panasonic encouraged us to contact our „FPGA supplier or Cypress for details“.
In conclusion, I’m asking you for the more information for the described application. Is there a „ready-to-use“ application with the code for the FX3 and the FPGA? Which FPGA can/ should be used?
Rashi_Vatsa
Please let me know if you downloaded the  AN65974.zip attached with the app note. This folder has the FPGA files for the FPGA used in the app note
Please let me know if are looking for something else
Rashi
