Could you tell me about meaning of "length matching 500mils"?
AN70707 describes the following recommendation.
" It is recommended that all lines on the GPIF II bus are length-matched within 500 mils. "
I think the difference in length of each line is within 500mil.
Is it correct?
(Length A – Length B) and (Length B – Length C) and (Length C – Length A) <500mil
Nagata
USB Superspeed Peripherals
Hi Nagata,
Yes, you are right. The difference in length between each line < 500 mils. For a GPIF case, difference in length between any two GPIF line must lie within the 500 mils range.
AliAsgar
Hi Nagata,
AliAsgar
