cy7C68013 C0.C2 mode
 i have write a  firmware, and use the kneil 4 to compile it, when output, i use the command as below:
Hex2bix.exe -i  -o bulktogpif.iic bulktogpif.hex -f 0xC2 -v 0x0451 -p 0x32AF
    the i use the control center download it to EEPROM, and the software show it programmed successfully, and i also load
    the sprit file and display the sprit,
    But, it seems that the usb is started as the C0 mode,
    can you help me, how can i know whether EEPROM is programming successfully and the 68013 is working by load the firmware which is written by myself?
