Can the CYUSBS234 DVK have the CY7C65211 swapped out with the A version to be configured in SPI mode as a virtual COM port? If so will the configuration utility allow the SPI configuration?
ispn:38623:1:0
l1:314:1:0
Yes the USB-Serial 'A' parts are pin compatible with the 'non-A' parts and can be swapped on the DVKs.
CY7C65211 can be swapped with the CY7C65211A part on the CYUSBS234 DVK.
Yatheesh
Yatheesh
Hi Yatheesh,
Thank you for the response.
Do you know if these devices can be configured outside of the configuration utility in a scripted process to speed up configuring multiple parts?
Jake
Hello Jake,
Yes, we have a command line tool to batch program USB-Serial Devices with a specific configuration.
Please refer to this thread: Re: CY7C65211 Serial Communication Mode
Let me know if you have any queries on the programming part.
Yatheesh
