I developed a software for CY7C64315 and tested with CY3660 Development Kit.
I use a MiniProg1 to program the development board and everything worked fine.
Now, I'm trying to program a chip CY7C64315 using Miniprog1 and ISSP(5pin connector), but the PSoC-Programmer software can't acquire the device to program the HEX file into it.
Is there any incompatibility with Miniprog1 and CY7C64315?
Any help and advice would be appreciated.
@anne_4609456
Hello @anne_4609456 ,
SCLK (white cable) should go to pin 4 P1.1, and SDATA (green cable) should do to Pin 9 P1.0.
Sampath
MiniProg1 can program the CY7C64315. You have also found it worked earlier on CY3660 DVK. Kindly try turning off auto-detection, and selecting the device manually, as shown in the following picture.
If it still does not work, a copy of the logs, or a screenshot of the error message would help us understand the issue better.
Sampath Selvaraj
Hello @SampathS_11
Follow attached images from PsocProgrammer and circuit.
I'm using only pins 5(VSS), 6(D+), 7(D-) and 8(VDD) on CY7C64315-16LKXC.
What am I doing wrong or missing?
@anne_4609456
Hello @SampathS_11
Did you have a chance to check my last reply and attached screen shot/ connection pictures?
Could you help me to program that chip ?
What am I doing wrong?
@anne_4609456
Sampath
