03:32 AM
Nov 05, 2018
03:32 AM
I have to migrate some c# hostapplications, depending on AN21XX based controller, which are using EZBUSB.Sys driver to WIN10 64bit.
Can you please give me some hints for the recommended method?
Is it possible to use the Cypress Suite USB 3.4.7 ?
Nov 06, 2018
02:35 AM
Nov 06, 2018
02:35 AM
Nov 06, 2018
01:44 AM
Nov 06, 2018
01:44 AM
Please refer section 9 of the attached Cypress CyUsb3.sys Programmer's Reference. This may help you.
Nov 06, 2018
02:11 AM
Nov 06, 2018
02:11 AM
Thanks for your reply!
Unfortunatly the „attached Cypress CyUsb3.sys Programmer's Reference“ is missing.
I found the „Cypress CyUsb3.sys Programmer's Reference“ dated ©2012 online, but Section 9 is missing.
Klaus Homberg
Nov 06, 2018
02:35 AM
Nov 06, 2018
02:35 AM
Nov 15, 2018
10:10 PM
Nov 15, 2018
10:10 PM
Hello Klaus Homberg,
Please use the FX3 SDK as it contains the latest drivers and library files.
Srinath S
