USB to NAND Flash Interface
I have a requirement of writing a NAND flash memory of size 8GB through a USB interface. My choice is to use CYWB0124AB - Westbridge IC since the processor on board could also control the NAND flash along with the USB.
The Question I have is weather the the Westbridge IC supports read/write of  x8 MLC/eMMC NAND flash of 8GB?
If possible could you suggest NAND Flash IC's form Cypress with density of 8GB.
Also is there a better alternate for the requirement.
Thanks & Regards,
Rakesh
Hemanth
First like given First question asked 750 replies posted
Hello Rakesh,
You can consider CYUSB202X SD2 which supports MMC version 4.4. This does not have a Raw Nand interface.
You can find the SD2 datasheet in the following link:
http://www.cypress.com/file/123391/download
Hemanth
Hemanth
Hemanth
Hello Rakesh,
Hemanth
Hemanth
