Hi all,
I am working on cypress FX3. I need to pass data from host to FPGA through cypress. I am stuck with DMA buffer and endpoint creation concept.
1.How the data in exchange between one end point to another endpoint?
2. is DMA buffer needed for USB data read ? is it possible to read USB data without DMA.
- Based on your description you intend to send the data from USB Endpoint to GPIF interface of FX3.
- To do that you need to create a DMA channel between USB Producer Socket and PIB Consumer Socket.
Please refer to following App Note where it is implemented:
Hemanth
Hemanth
Thanks for answer and i got source code and related document. The source code is for 32 bit interface, but FPGA output is only 8 bit. How to i configure 8 bit GPIF ll instead of 32 bit .
Please check the GPIF designer project in the following path:
AN65974\FX3 Firmware\GPIFII_Designer_sync_SlaveFIFO.cydsn
- In this you need to change the bus width to 8 (and make sure that the pins displayed in the IO matrix display for the GPIF interface are connected to FPGA)
- Along with this in the firmware, you need to assign the macro CY_FX_SLFIFO_GPIF_16_32BIT_CONF_SELECT to 0.
Hemanth
Thank you Hemanth sir, i will try and let you know.
