we are using this (CY7C65215)chip set for converting USB port to Spi interface.
(Desktop-PC)Linux is at the USB port and spi device at the other end.
our Questions on this are
(1)when we connect to Desktop pc how it is enemurated?
Ex:a)we will first see lsusb there we can get the vendor id and product id:
b)As we are keeping spi on other end it should be shown as a device node in /dev/ttyXXX
The above device node /dev/ttyXXX is not shown in our device when we connected to Desktop pc
Is there any driver installation required for this board in linux.
I have seen some cypress configuration in kernel configuration may i know what these configurations for
kmod-usb-serial-cypress-m8
This configuration is to be enabled or disabled ? for the above interface.
What are the drivers required in linux to enable and enumerate the device in /dev/ttyXXX?
Thanks in advance.
Sujith
Hello Sujith,
We were able to check the I2C and SPI write/read operations as per your page address and length and both were successful.The Test Utility will only be able to communicate with the on-board I2C/SPI EEPROMS, please ensure that the jumper settings are proper if you are using our DVK. If you are using your own I2C/SPI device please ensure that the address and memory array is same as those used in our DVK.
Sananya
Hi Sujith,
The device will be visible under the /dev/ttyXXX node if it Is configured for UART interface and binds to CDC ACM driver. If it is configured for SPI interface, it will come up as a vendor device and no specific drivers will be required since Libusb library is used to communicate with the device which is also provided in the USB-Serial Linux SDK. Please verify if the device enumerates properly with the dmesg command.
Please attach a screenshot where the Kernel configuration is displayed.
Sananya
Hi Sanm,
Thanks for the reply,
I am attaching a screenshot for kernel configuration and also i have seen libusb sdk and test utility library for testing spi and i2c working or not?
we found the below errors
when configured as spi device we got error like:Data corruption occured!!
when configured as i2c device we got error like:Error in doing i2c write
attached the above two logs too
can you please help us why this happens and also how to resolve it.
kernel configuration:
log for spi configuration:
root@hp:~/Downloads/spi/CyUSBSerial_SDK_Linux/CyUSBSerial_SDK_Linux/linux/testUtility$ sudo ./CyUSBSerialTestUtility
Device Number | VID | PID | INTERFACE NUMBER | FUNCTIONALITY
0 |4b4 |a | 0 | VENDOR_SPI
0 |4b4 |a | 1 | VENDOR_I2C
0 |4b4 |a | 2 | NA
1: Print list of devices
2: Select device...No device selected !!
3: Enter I2C/SPI Flash page address and length to write/read.
4: Verify data
5: Exit
2
Enter Device number to be selected..
0
Enter interface number..
0
2: Change device selection--selected device: [Device number 0] : [Interface No 0] : SPI
4: Verify data
5: Exit
3
Enter Page address... (less than 65536)
1234
Enter length to read/write...(less than 256)
32
3: Change Flash page address and length ...Entered is page address 1234 and length 32
4: Verify data
5: Exit
4
Calling spi write enable
The Data written is ...
67 c6 69 73 51 ff 4a ec 29 cd ba ab f2 fb e3 46 7c c2 54 f8 1b e8 e7 8d 76 5a 2e 63 33 9f c9 9a
Data Read back is
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
4: Verify data
5: Exit
log for I2C configuration:
0 |4b4 |a | 2 | NA
4: Verify data
5: Exit
2
0
1
2: Change device selection--selected device: [Device number 0] : [Interface No 1] : I2C
4: Verify data
5: Exit
3
Enter Page address... (less than 256)
124
Enter length to read/write...(less than 64)
32
3: Change Flash page address and length ...Entered is page address 124 and length 32
4: Verify data
5: Exit
4
Calling I2C
Data that is written on to i2c ...
4: Verify data
5: Exit
Sujith
Hello Sujith,
Sananya
