Failed to perform FX3 Debug through J-Link
ChRO_4339966
I am trying to perform FX3 Debug through Segger J-Link module.
I followed EzUsbSuite_UG.pdf recommandations and most of the process is OK.
I then face following error message from Eclipse :
"Error in final launch sequence
Failed to execute MI command:
symbol-file C:\\Users\\XXX\\dev\\en_cours\\directC\\FX3\\Debug\\katsu.elf
Error message from debugger back end:
value has been optimized out
Can you help ?
Thanks for support
Below is Eclipse log
SEGGER J-Link GDB Server V6.70 Command Line Version
JLinkARM.dll V6.70 (DLL compiled Mar 27 2020 14:35:04)
Command line: -if jtag -device ARM9 -endian little -speed 1000 -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -s
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      localhost only
Generate logfile:              off
Verify download:               on
Init regs on start:            on
Silent mode:                   off
Single run mode:               on
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 ARM9
Target interface:              JTAG
Target interface speed:        1000kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V10 compiled Mar 19 2020 11:10:39
Hardware: V10.10
S/N: 260105459
OEM: SEGGER-EDU
Feature(s): FlashBP, GDB
Checking target voltage...
Target voltage: 2.40 V
Listening on TCP/IP port 2331
Connecting to target...
J-Link found 1 JTAG device, Total IRLen = 4
JTAG ID: 0x07926069 (ARM9)
Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 1 bytes @ address 0x00000000 (Data = 0xB4)
Reading 64 bytes @ address 0x00000000
Received monitor command: speed 1000
Target interface speed set to 1000 kHz
Received monitor command: clrbp
Received monitor command: reset
WARNING: PC of target system has unexpected value of 0xF01386D0 after reset.
Resetting target
Received monitor command: halt
Halting target CPU...
...Target halted (PC = 0x00000000)
Received monitor command: regs
PC = 00000000, CPSR = 000000D3 (SVC mode, ARM FIQ dis. IRQ dis.)
R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
USR: R8 =00000000, R9 =00000000, R10=00000000, R11 =00000000, R12 =00000000
     R13=00000000, R14=00000000
FIQ: R8 =00000000, R9 =00000000, R10=00000000, R11 =00000000, R12 =00000000
     R13=00000000, R14=00000000, SPSR=00000010
SVC: R13=00000000, R14=00000000, SPSR=00000010
ABT: R13=00000000, R14=00000000, SPSR=00000010
IRQ: R13=00000000, R14=00000000, SPSR=00000010
UND: R13=00000000, R14=00000000, SPSR=00000010
Received monitor command: speed auto
Select auto target interface speed (7827 kHz)
Received monitor command: flash breakpoints 0
Flash breakpoints disabled
Downloading 9512 bytes @ address 0x00000100 - Verified OK
Downloading 16304 bytes @ address 0x40003000 - Verified OK
Downloading 16288 bytes @ address 0x40006FB0 - Verified OK
Downloading 15244 bytes @ address 0x4000AF50 - Verified OK
Downloading 228 bytes @ address 0x4000EADC - Verified OK
Downloading 332 bytes @ address 0x4000EBC0 - Verified OK
Downloading 452 bytes @ address 0x4000ED0C - Verified OK
Downloading 240 bytes @ address 0x4000EED0 - Verified OK
Downloading 216 bytes @ address 0x4000EFC0 - Verified OK
Downloading 132 bytes @ address 0x4000F098 - Verified OK
Downloading 16 bytes @ address 0x4000F11C - Verified OK
Downloading 16 bytes @ address 0x4000F12C - Verified OK
Downloading 160 bytes @ address 0x4000F13C - Verified OK
Downloading 92 bytes @ address 0x4000F1DC - Verified OK
Downloading 232 bytes @ address 0x4000F238 - Verified OK
Downloading 212 bytes @ address 0x4000F320 - Verified OK
Downloading 68 bytes @ address 0x4000F3F4 - Verified OK
Downloading 80 bytes @ address 0x4000F438 - Verified OK
Downloading 536 bytes @ address 0x4000F488 - Verified OK
Downloading 80 bytes @ address 0x4000F6A0 - Verified OK
Downloading 404 bytes @ address 0x4000F6F0 - Verified OK
Downloading 92 bytes @ address 0x4000F884 - Verified OK
Downloading 280 bytes @ address 0x4000F8E0 - Verified OK
Downloading 240 bytes @ address 0x4000F9F8 - Verified OK
Downloading 444 bytes @ address 0x4000FAE8 - Verified OK
Downloading 68 bytes @ address 0x4000FCA4 - Verified OK
Downloading 172 bytes @ address 0x4000FCE8 - Verified OK
Downloading 544 bytes @ address 0x4000FD94 - Verified OK
Downloading 552 bytes @ address 0x4000FFB4 - Verified OK
Downloading 324 bytes @ address 0x400101DC - Verified OK
Downloading 16 bytes @ address 0x40010320 - Verified OK
Downloading 304 bytes @ address 0x40010330 - Verified OK
Downloading 132 bytes @ address 0x40010460 - Verified OK
Downloading 84 bytes @ address 0x400104E4 - Verified OK
Downloading 752 bytes @ address 0x40010538 - Verified OK
Downloading 152 bytes @ address 0x40010828 - Verified OK
Downloading 620 bytes @ address 0x400108C0 - Verified OK
Downloading 1016 bytes @ address 0x40010B2C - Verified OK
Downloading 180 bytes @ address 0x40010F24 - Verified OK
Downloading 212 bytes @ address 0x40010FD8 - Verified OK
Downloading 436 bytes @ address 0x400110AC - Verified OK
Downloading 820 bytes @ address 0x40011260 - Verified OK
Downloading 288 bytes @ address 0x40011594 - Verified OK
Downloading 140 bytes @ address 0x400116B4 - Verified OK
Downloading 248 bytes @ address 0x40011740 - Verified OK
Downloading 100 bytes @ address 0x40011838 - Verified OK
Downloading 436 bytes @ address 0x4001189C - Verified OK
Downloading 220 bytes @ address 0x40011A50 - Verified OK
Downloading 416 bytes @ address 0x40011B2C - Verified OK
Downloading 492 bytes @ address 0x40011CCC - Verified OK
Downloading 544 bytes @ address 0x40011EB8 - Verified OK
Downloading 236 bytes @ address 0x400120D8 - Verified OK
Downloading 304 bytes @ address 0x400121C4 - Verified OK
Downloading 420 bytes @ address 0x400122F4 - Verified OK
Downloading 268 bytes @ address 0x40012498 - Verified OK
Downloading 276 bytes @ address 0x400125A4 - Verified OK
Downloading 220 bytes @ address 0x400126B8 - Verified OK
Downloading 52 bytes @ address 0x40012794 - Verified OK
Downloading 104 bytes @ address 0x400127C8 - Verified OK
Downloading 412 bytes @ address 0x40012830 - Verified OK
Downloading 128 bytes @ address 0x400129CC - Verified OK
Downloading 16 bytes @ address 0x40012A4C - Verified OK
Downloading 576 bytes @ address 0x40012A5C - Verified OK
Downloading 228 bytes @ address 0x40012C9C - Verified OK
Downloading 664 bytes @ address 0x40012D80 - Verified OK
Downloading 108 bytes @ address 0x40013018 - Verified OK
Downloading 152 bytes @ address 0x40013084 - Verified OK
Downloading 336 bytes @ address 0x4001311C - Verified OK
Downloading 152 bytes @ address 0x4001326C - Verified OK
Downloading 1168 bytes @ address 0x40013304 - Verified OK
Downloading 44 bytes @ address 0x40013794 - Verified OK
Downloading 244 bytes @ address 0x400137C0 - Verified OK
Downloading 192 bytes @ address 0x400138B4 - Verified OK
Downloading 156 bytes @ address 0x40013974 - Verified OK
Downloading 64 bytes @ address 0x40013A10 - Verified OK
Downloading 156 bytes @ address 0x40013A50 - Verified OK
Downloading 960 bytes @ address 0x40013AEC - Verified OK
Downloading 1536 bytes @ address 0x40013EAC - Verified OK
Downloading 1516 bytes @ address 0x400144AC - Verified OK
Downloading 1684 bytes @ address 0x40014A98 - Verified OK
Downloading 80 bytes @ address 0x4001512C - Verified OK
Downloading 248 bytes @ address 0x4001517C - Verified OK
Downloading 64 bytes @ address 0x40015274 - Verified OK
Downloading 276 bytes @ address 0x400152B4 - Verified OK
Downloading 60 bytes @ address 0x400153C8 - Verified OK
Downloading 60 bytes @ address 0x40015404 - Verified OK
Downloading 112 bytes @ address 0x40015440 - Verified OK
Downloading 336 bytes @ address 0x400154B0 - Verified OK
Downloading 140 bytes @ address 0x40015600 - Verified OK
Downloading 224 bytes @ address 0x4001568C - Verified OK
Downloading 16 bytes @ address 0x4001576C - Verified OK
Downloading 84 bytes @ address 0x4001577C - Verified OK
Downloading 156 bytes @ address 0x400157D0 - Verified OK
Downloading 256 bytes @ address 0x4001586C - Verified OK
Downloading 164 bytes @ address 0x4001596C - Verified OK
Downloading 144 bytes @ address 0x40015A10 - Verified OK
Downloading 628 bytes @ address 0x40015AA0 - Verified OK
Downloading 340 bytes @ address 0x40015D14 - Verified OK
Downloading 192 bytes @ address 0x40015E68 - Verified OK
Downloading 56 bytes @ address 0x40015F28 - Verified OK
Downloading 52 bytes @ address 0x40015F60 - Verified OK
Downloading 48 bytes @ address 0x40015F94 - Verified OK
Downloading 24 bytes @ address 0x40015FC4 - Verified OK
Downloading 24 bytes @ address 0x40015FDC - Verified OK
Downloading 28 bytes @ address 0x40015FF4 - Verified OK
Downloading 132 bytes @ address 0x40016010 - Verified OK
Downloading 252 bytes @ address 0x40016094 - Verified OK
Downloading 176 bytes @ address 0x40016190 - Verified OK
Downloading 140 bytes @ address 0x40016240 - Verified OK
Downloading 156 bytes @ address 0x400162CC - Verified OK
Downloading 40 bytes @ address 0x40016368 - Verified OK
Downloading 16 bytes @ address 0x40016390 - Verified OK
Downloading 416 bytes @ address 0x400163A0 - Verified OK
Downloading 296 bytes @ address 0x40016540 - Verified OK
Downloading 80 bytes @ address 0x40016668 - Verified OK
Downloading 304 bytes @ address 0x400166B8 - Verified OK
Downloading 216 bytes @ address 0x400167E8 - Verified OK
Downloading 32 bytes @ address 0x400168C0 - Verified OK
Downloading 132 bytes @ address 0x400168E0 - Verified OK
Downloading 12 bytes @ address 0x40016964 - Verified OK
Downloading 12 bytes @ address 0x40016970 - Verified OK
Downloading 16 bytes @ address 0x4001697C - Verified OK
Downloading 16 bytes @ address 0x4001698C - Verified OK
Downloading 20 bytes @ address 0x4001699C - Verified OK
Downloading 16 bytes @ address 0x400169B0 - Verified OK
Downloading 12 bytes @ address 0x400169C0 - Verified OK
Downloading 20 bytes @ address 0x400169CC - Verified OK
Downloading 60 bytes @ address 0x400169E0 - Verified OK
Downloading 40 bytes @ address 0x40016A1C - Verified OK
Downloading 124 bytes @ address 0x40016A44 - Verified OK
Downloading 316 bytes @ address 0x40016AC0 - Verified OK
Downloading 112 bytes @ address 0x40016BFC - Verified OK
Downloading 356 bytes @ address 0x40016C6C - Verified OK
Downloading 80 bytes @ address 0x40016DD0 - Verified OK
Downloading 688 bytes @ address 0x40016E20 - Verified OK
Downloading 388 bytes @ address 0x400170D0 - Verified OK
Downloading 96 bytes @ address 0x40017254 - Verified OK
Downloading 160 bytes @ address 0x400172B4 - Verified OK
Downloading 224 bytes @ address 0x40017354 - Verified OK
Downloading 224 bytes @ address 0x40017434 - Verified OK
Downloading 72 bytes @ address 0x40017514 - Verified OK
Downloading 172 bytes @ address 0x4001755C - Verified OK
Downloading 116 bytes @ address 0x40017608 - Verified OK
Downloading 212 bytes @ address 0x4001767C - Verified OK
Downloading 356 bytes @ address 0x40017750 - Verified OK
Downloading 200 bytes @ address 0x400178B4 - Verified OK
Downloading 160 bytes @ address 0x4001797C - Verified OK
Downloading 16 bytes @ address 0x40017A1C - Verified OK
Downloading 36 bytes @ address 0x40017A2C - Verified OK
Downloading 104 bytes @ address 0x40017A50 - Verified OK
Downloading 4 bytes @ address 0x40017AB8 - Verified OK
Downloading 584 bytes @ address 0x40017ABC - Verified OK
Downloading 16 bytes @ address 0x40017D04 - Verified OK
Downloading 204 bytes @ address 0x40017D14 - Verified OK
Downloading 192 bytes @ address 0x40017DE0 - Verified OK
Downloading 16 bytes @ address 0x40017EA0 - Verified OK
Downloading 1360 bytes @ address 0x40017EB0 - Verified OK
Downloading 132 bytes @ address 0x40018400 - Verified OK
Downloading 456 bytes @ address 0x40018484 - Verified OK
Downloading 344 bytes @ address 0x4001864C - Verified OK
Downloading 248 bytes @ address 0x400187A4 - Verified OK
Downloading 372 bytes @ address 0x4001889C - Verified OK
Downloading 188 bytes @ address 0x40018A10 - Verified OK
Downloading 440 bytes @ address 0x40018ACC - Verified OK
Downloading 180 bytes @ address 0x40018C84 - Verified OK
Downloading 4 bytes @ address 0x40018D38 - Verified OK
Downloading 16 bytes @ address 0x40018D3C - Verified OK
Downloading 16 bytes @ address 0x40018D4C - Verified OK
Downloading 76 bytes @ address 0x40018D5C - Verified OK
Downloading 104 bytes @ address 0x40018DA8 - Verified OK
Downloading 108 bytes @ address 0x40018E10 - Verified OK
Downloading 124 bytes @ address 0x40018E7C - Verified OK
Downloading 180 bytes @ address 0x40018EF8 - Verified OK
Downloading 588 bytes @ address 0x40018FAC - Verified OK
Downloading 892 bytes @ address 0x400191F8 - Verified OK
Downloading 12 bytes @ address 0x40019574 - Verified OK
Downloading 4 bytes @ address 0x40019580 - Verified OK
Downloading 800 bytes @ address 0x40019584 - Verified OK
Downloading 212 bytes @ address 0x400198A4 - Verified OK
Downloading 120 bytes @ address 0x40019978 - Verified OK
Downloading 592 bytes @ address 0x400199F0 - Verified OK
Downloading 244 bytes @ address 0x40019C40 - Verified OK
Downloading 456 bytes @ address 0x40019D34 - Verified OK
Downloading 436 bytes @ address 0x40019EFC - Verified OK
Downloading 168 bytes @ address 0x4001A0B0 - Verified OK
Downloading 340 bytes @ address 0x4001A158 - Verified OK
Downloading 1008 bytes @ address 0x4001A2AC - Verified OK
Downloading 940 bytes @ address 0x4001A69C - Verified OK
Downloading 128 bytes @ address 0x4001AA48 - Verified OK
Downloading 128 bytes @ address 0x4001AAC8 - Verified OK
Downloading 120 bytes @ address 0x4001AB48 - Verified OK
Downloading 420 bytes @ address 0x4001ABC0 - Verified OK
Downloading 528 bytes @ address 0x4001AD64 - Verified OK
Downloading 640 bytes @ address 0x4001AF74 - Verified OK
Downloading 208 bytes @ address 0x4001B1F4 - Verified OK
Downloading 60 bytes @ address 0x4001B2C4 - Verified OK
Downloading 160 bytes @ address 0x4001B300 - Verified OK
Downloading 160 bytes @ address 0x4001B3A0 - Verified OK
Downloading 1272 bytes @ address 0x4001B440 - Verified OK
Downloading 316 bytes @ address 0x4001B938 - Verified OK
Downloading 1572 bytes @ address 0x4001BA74 - Verified OK
Downloading 196 bytes @ address 0x4001C098 - Verified OK
Downloading 164 bytes @ address 0x4001C15C - Verified OK
Downloading 124 bytes @ address 0x4001C200 - Verified OK
Downloading 360 bytes @ address 0x4001C27C - Verified OK
Downloading 132 bytes @ address 0x4001C3E4 - Verified OK
Downloading 608 bytes @ address 0x4001C468 - Verified OK
Downloading 28 bytes @ address 0x4001C6C8 - Verified OK
Downloading 544 bytes @ address 0x4001C6E4 - Verified OK
Downloading 696 bytes @ address 0x4001C904 - Verified OK
Downloading 184 bytes @ address 0x4001CBBC - Verified OK
Downloading 280 bytes @ address 0x4001CC74 - Verified OK
Downloading 1204 bytes @ address 0x4001CD8C - Verified OK
Downloading 248 bytes @ address 0x4001D240 - Verified OK
Downloading 304 bytes @ address 0x4001D338 - Verified OK
Downloading 540 bytes @ address 0x4001D468 - Verified OK
Downloading 84 bytes @ address 0x4001D684 - Verified OK
Downloading 16 bytes @ address 0x4001D6D8 - Verified OK
Downloading 96 bytes @ address 0x4001D6E8 - Verified OK
Downloading 376 bytes @ address 0x4001D748 - Verified OK
Downloading 80 bytes @ address 0x4001D8C0 - Verified OK
Downloading 568 bytes @ address 0x4001D910 - Verified OK
Downloading 480 bytes @ address 0x4001DB48 - Verified OK
Downloading 424 bytes @ address 0x4001DD28 - Verified OK
Downloading 528 bytes @ address 0x4001DED0 - Verified OK
Downloading 2128 bytes @ address 0x4001E0E0 - Verified OK
Downloading 80 bytes @ address 0x4001E930 - Verified OK
Downloading 304 bytes @ address 0x4001E980 - Verified OK
Downloading 824 bytes @ address 0x4001EAB0 - Verified OK
Downloading 92 bytes @ address 0x4001EDE8 - Verified OK
Downloading 32 bytes @ address 0x4001EE44 - Verified OK
Downloading 104 bytes @ address 0x4001EE64 - Verified OK
Downloading 40 bytes @ address 0x4001EECC - Verified OK
Downloading 32 bytes @ address 0x4001EEF4 - Verified OK
Downloading 276 bytes @ address 0x4001EF14 - Verified OK
Downloading 12 bytes @ address 0x4001F028 - Verified OK
Downloading 16 bytes @ address 0x4001F034 - Verified OK
Downloading 20 bytes @ address 0x4001F044 - Verified OK
Downloading 20 bytes @ address 0x4001F058 - Verified OK
Downloading 12 bytes @ address 0x4001F06C - Verified OK
Downloading 64 bytes @ address 0x4001F078 - Verified OK
Downloading 64 bytes @ address 0x4001F0B8 - Verified OK
Downloading 24 bytes @ address 0x4001F0F8 - Verified OK
Downloading 404 bytes @ address 0x4001F110 - Verified OK
Downloading 64 bytes @ address 0x4001F2A4 - Verified OK
Downloading 16 bytes @ address 0x4001F2E4 - Verified OK
Downloading 16 bytes @ address 0x4001F2F4 - Verified OK
Downloading 16 bytes @ address 0x4001F304 - Verified OK
Downloading 16 bytes @ address 0x4001F314 - Verified OK
Downloading 208 bytes @ address 0x4001F324 - Verified OK
Downloading 628 bytes @ address 0x4001F3F4 - Verified OK
Downloading 168 bytes @ address 0x4001F668 - Verified OK
Downloading 116 bytes @ address 0x4001F710 - Verified OK
Downloading 40 bytes @ address 0x4001F784 - Verified OK
Downloading 40 bytes @ address 0x4001F7AC - Verified OK
Downloading 40 bytes @ address 0x4001F7D4 - Verified OK
Downloading 40 bytes @ address 0x4001F7FC - Verified OK
Downloading 40 bytes @ address 0x4001F824 - Verified OK
Downloading 40 bytes @ address 0x4001F84C - Verified OK
Downloading 40 bytes @ address 0x4001F874 - Verified OK
Downloading 48 bytes @ address 0x4001F89C - Verified OK
Downloading 104 bytes @ address 0x4001F8CC - Verified OK
Downloading 20 bytes @ address 0x4001F934 - Verified OK
Downloading 20 bytes @ address 0x4001F948 - Verified OK
Downloading 84 bytes @ address 0x4001F95C - Verified OK
Downloading 48 bytes @ address 0x4001F9B0 - Verified OK
Downloading 24 bytes @ address 0x4001F9E0 - Verified OK
Downloading 24 bytes @ address 0x4001F9F8 - Verified OK
Downloading 68 bytes @ address 0x4001FA10 - Verified OK
Downloading 48 bytes @ address 0x4001FA54 - Verified OK
Downloading 44 bytes @ address 0x4001FA84 - Verified OK
Downloading 128 bytes @ address 0x4001FAB0 - Verified OK
Downloading 148 bytes @ address 0x4001FB30 - Verified OK
Downloading 168 bytes @ address 0x4001FBC4 - Verified OK
Downloading 88 bytes @ address 0x4001FC6C - Verified OK
Downloading 112 bytes @ address 0x4001FCC4 - Verified OK
Downloading 100 bytes @ address 0x4001FD34 - Verified OK
Downloading 264 bytes @ address 0x4001FD98 - Verified OK
Downloading 376 bytes @ address 0x4001FEA0 - Verified OK
Downloading 132 bytes @ address 0x40020018 - Verified OK
Downloading 104 bytes @ address 0x4002009C - Verified OK
Downloading 276 bytes @ address 0x40020104 - Verified OK
Downloading 256 bytes @ address 0x40020218 - Verified OK
Downloading 452 bytes @ address 0x40020318 - Verified OK
Downloading 1540 bytes @ address 0x400204DC - Verified OK
Downloading 324 bytes @ address 0x40020AE0 - Verified OK
Downloading 236 bytes @ address 0x40020C24 - Verified OK
Downloading 580 bytes @ address 0x40020D10 - Verified OK
Downloading 80 bytes @ address 0x40020F54 - Verified OK
Downloading 272 bytes @ address 0x40020FA4 - Verified OK
Downloading 400 bytes @ address 0x400210B4 - Verified OK
Downloading 320 bytes @ address 0x40021244 - Verified OK
Downloading 128 bytes @ address 0x40021384 - Verified OK
Downloading 192 bytes @ address 0x40021404 - Verified OK
Downloading 104 bytes @ address 0x400214C4 - Verified OK
Downloading 376 bytes @ address 0x4002152C - Verified OK
Downloading 128 bytes @ address 0x400216A4 - Verified OK
Downloading 212 bytes @ address 0x40021724 - Verified OK
Downloading 160 bytes @ address 0x400217F8 - Verified OK
Downloading 440 bytes @ address 0x40021898 - Verified OK
Downloading 160 bytes @ address 0x40021A50 - Verified OK
Downloading 160 bytes @ address 0x40021AF0 - Verified OK
Downloading 160 bytes @ address 0x40021B90 - Verified OK
Downloading 612 bytes @ address 0x40021C30 - Verified OK
Downloading 116 bytes @ address 0x40021E94 - Verified OK
Downloading 160 bytes @ address 0x40021F08 - Verified OK
Downloading 52 bytes @ address 0x40021FA8 - Verified OK
Downloading 64 bytes @ address 0x40021FDC - Verified OK
Downloading 64 bytes @ address 0x4002201C - Verified OK
Downloading 136 bytes @ address 0x4002205C - Verified OK
Downloading 456 bytes @ address 0x400220E4 - Verified OK
Downloading 64 bytes @ address 0x400222AC - Verified OK
Downloading 712 bytes @ address 0x400222EC - Verified OK
Downloading 208 bytes @ address 0x400225B4 - Verified OK
Downloading 600 bytes @ address 0x40022684 - Verified OK
Downloading 440 bytes @ address 0x400228DC - Verified OK
Downloading 460 bytes @ address 0x40022A94 - Verified OK
Downloading 588 bytes @ address 0x40022C60 - Verified OK
Downloading 720 bytes @ address 0x40022EAC - Verified OK
Downloading 1512 bytes @ address 0x4002317C - Verified OK
Downloading 168 bytes @ address 0x40023764 - Verified OK
Downloading 472 bytes @ address 0x4002380C - Verified OK
Downloading 732 bytes @ address 0x400239E4 - Verified OK
Downloading 756 bytes @ address 0x40023CC0 - Verified OK
Downloading 136 bytes @ address 0x40023FB4 - Verified OK
Downloading 1236 bytes @ address 0x4002403C - Verified OK
Downloading 524 bytes @ address 0x40024510 - Verified OK
Downloading 956 bytes @ address 0x4002471C - Verified OK
Downloading 1120 bytes @ address 0x40024AD8 - Verified OK
Downloading 940 bytes @ address 0x40024F38 - Verified OK
Downloading 828 bytes @ address 0x400252E4 - Verified OK
Downloading 424 bytes @ address 0x40025620 - Verified OK
Downloading 416 bytes @ address 0x400257C8 - Verified OK
Downloading 752 bytes @ address 0x40025968 - Verified OK
Downloading 464 bytes @ address 0x40025C58 - Verified OK
Downloading 156 bytes @ address 0x40025E28 - Verified OK
Downloading 212 bytes @ address 0x40025EC4 - Verified OK
Downloading 76 bytes @ address 0x40025F98 - Verified OK
Downloading 176 bytes @ address 0x40025FE4 - Verified OK
Downloading 968 bytes @ address 0x40026094 - Verified OK
Downloading 360 bytes @ address 0x4002645C - Verified OK
Downloading 108 bytes @ address 0x400265C4 - Verified OK
Downloading 320 bytes @ address 0x40026630 - Verified OK
Downloading 300 bytes @ address 0x40026770 - Verified OK
Downloading 508 bytes @ address 0x4002689C - Verified OK
Downloading 628 bytes @ address 0x40026A98 - Verified OK
Downloading 60 bytes @ address 0x40026D0C - Verified OK
Downloading 164 bytes @ address 0x40026D48 - Verified OK
Downloading 428 bytes @ address 0x40026DEC - Verified OK
Downloading 148 bytes @ address 0x40026F98 - Verified OK
Downloading 208 bytes @ address 0x4002702C - Verified OK
Downloading 208 bytes @ address 0x400270FC - Verified OK
Downloading 628 bytes @ address 0x400271CC - Verified OK
Downloading 232 bytes @ address 0x40027440 - Verified OK
Downloading 2068 bytes @ address 0x40030000 - Verified OK
Writing register (R8 = 0x40015928)
GDB closed TCP/IP connection
Hello Christophe,
Please try replacing {cross_prefix} by arm-none-eabi-
Please try this and let me know the results. If this doesn't work share the snippet of Debugger tab again
Rashi
Rashi
