Nov 25, 2021
08:14 PM
Nov 25, 2021
08:14 PM
Hi
I am having one more problem with FX2LP while streaming video data.
Please help us to understand if while requesting data from FX2LP is there a possibility of FX2LP endpoint buffer getting stuck? Means FLAGB activity stops and no further data exchange happens.
When I was testing on EVK with the bulksrc example I found that if the EP buffer is not full and you request data from it then it will get stuck. Can the same scenario happen in webcam stream mode also? If so, then what are all the conditions in which we can get into this state? Please help to understand this.
Labels
