Hello
I try to setup an isochronous endpoint to read data from an external application. As it did not work out, I setup the following minimal example which does not work either. The example should simply feed the computer with data.
WORD i; REVCTL = (1 << 1) | (1 << 0); // DYN_OUT, ENH_PKT SYNCDELAY; CPUCS = (2 << 3) | (1 << 1); // 48MHz CPU clock, CLKOUT enable SYNCDELAY; IFCONFIG = (1 << 7) | (1 << 6) | (1 << 3) | (3 << 0); // internal 48MHz FIFO clock, asynchronous I/O, slave FIFO SYNCDELAY; EP2CFG = 0; // EP2: off SYNCDELAY; EP4CFG = 0; // EP4: off SYNCDELAY; EP6CFG = (1 << 7) | (1 << 6) | (1 << 4) | (2 << 0); // EP6: valid, in, isochronous, 512B, double buf SYNCDELAY; EP8CFG = 0; // EP8: off SYNCDELAY; RESETFIFOS(); EP2FIFOCFG = 0; // EP2: off SYNCDELAY; EP4FIFOCFG = 0; // EP4: off SYNCDELAY; EP6FIFOCFG = (1 << 0); // EP6: 16bit //EP6FIFOCFG = (1 << 3) | (1 << 0); // EP6: AUTOIN, 16bit SYNCDELAY; EP8FIFOCFG = 0; // EP8: off SYNCDELAY; PORTACFG = 0; SYNCDELAY; FIFOPINPOLAR = 0; // all FIFO control pins low-active SYNCDELAY; USE_USB_INTS(); ENABLE_SUDAV(); ENABLE_USBRESET(); ENABLE_HISPEED(); EA = 1; RENUMERATE_UNCOND(); while(TRUE) { for(i=0;i<512;i++){ EP6FIFOBUF = 0xee; } EP6BCH = 0x02; SYNCDELAY; EP6BCL = 0x00; SYNCDELAY; }
Whenever I try to read data from the endpoint, the FX2 always reports that there is no data available. How to fix this problem?
Thank you for your support!
Kind regards,
Peter
Endpoint configurations are not proper.
You have to use one of the endpoint configuration as shown in figure 2.5 in the datasheet http://www.cypress.com/?docID=45142
Vikas.
Thank you for your response. Is 0xD2 no valid endpoint configuration (e.g. no. 1 in figure 2-5)? Do I have to configure all endpoints in order to use EP6?
Kind regards,
Peter
