CY7C65211A (CDC mode)can be conneted to Cypress USB-Serial Configuration Utility.
Modified it to Vendor mode ,USB Serial Test Utility can find it,but Cypress USB-Serial Configuration Utility not.
How can I configure CY7C65211A back to CDC mode? THKs!
Please try the USB-Serial Configuration Utility from USB-Serial SDK present under the path:
<installation directory>\Cypress\USB-Serial SDK\bin
Also please let me know the USB-Serial Configuration Utility version which can be found under Help->About
Yatheesh
Yatheesh
