USB Low-Full-High Speed Peripherals
Good afternoon all,
Why we need INT0(PA0) and INT1(PA1) pins of cy7c68013a-56 pin? When we should use this pins?
Vimala
 These two pins can be used either as GPIOs or as interrupts.The INT0 and INT1 can be configured as either level triggered or edge triggered interrupts.
Vikas
