USB Low-Full-High Speed Peripherals
Hello sir,
I have one application and it is based on the following serial communication settings
Baud Rate:9600
Data Bits:7 bit
Parity:Even
Stop Bits:1
Flow Control:None
I have been using cypress ic CYC64225 with 9600 8-N-1
But this IC does not support 7-bit data format.
I have my hardware ready and I don't want to change it so finding pin to pin compatiblity with this IC.
Please suggest me IC part number which support 7/8 bit data format and also pin compatiblity with existing one.
Did you mean CY7C64225?
yes I am talking about the same
