Hi
Using the USB to I2C tool does not work, the developers recommend that we need to update the USB driver to 1.0.3.79 (File format: image file). Can you help with the driver?
The standard firmware version factory programmed on USB-Serial CY7C65215 is version 1.0.3.78 which is the latest one.
Please recheck the requirements.
Yatheesh
Please use the vendor driver (cyusb3) available on USB-Serial SDK (CypressDriverInstaller_1.exe) or from FX3 SDK.
Yatheesh
Dear Yatheesh,
The updated version is still 1.0.3.28
Is there a newer version of the driver than the linked page?
Thank you!!
http://e2e.ti.com/support/dlp/f/94/p/830276/3083335#3083335
The version which you are referring from the configuration utility to is the firmware version and not the driver version.
Driver version can be checked in device manager. Double click on the device in the device manager and under driver tab you will be able to see the driver provider, date and the driver version.
You can update the driver from the update driver option available under driver tab.
I will update you with the details on the firmware version.
Yatheesh
Yatheesh
